Ubuntu 18.04.
I am fiddling with settings on my Dell 7490 laptop to have it not go to sleep when on low battery.
I have got it to work but only after combining dconf settings in org.gnome.settings-daemon.plugins.power and /etc/UPower/UPower.conf settings.
Could somebody please explain what the difference between the two are, and if one takes priority over the other.
Thank you
yi_asb
  • 65
  • As you have experience in this area, can I solicit a comment on another user's question here: https://askubuntu.com/questions/1149643/laptop-not-shutting-down-on-low-power/1150124#1150124 – WinEunuuchs2Unix Jun 10 '19 at 23:06
takes precedence. Gnome moved from using org.gnome.settings-daemon.plugins.power for some of the options to this file so UPower.conf is a newer approach.
The file even claims users should not need to edit the file. So if you need to make changes to /etc/UPower/UPower.conf to make something work do consider this a bug that needs to be reported as it should affect every user that uses the same hardware.
Rinzwind
  • 293,910
  • 570
  • 710
