I have Ubuntu 12.04 installed on my laptop. When I go to Sound Settings while logged into my user, no sound card appears detected.
In spite of this, the sound on my laptop is working ok, and I can use alsamixer just fine. The Unity sound indicator is dead, and this is quite annoying.
If I login as guest, the sound indicator works just fine, I assume it's something related to my user's sound settings, but I cannot find what exactly.
Any clues?
Braiam
  • 66,947
  • 177
  • 264
usertwelve
  • 39
5 Answers5
I had the same problem on my MacBook Pro 8.1 running Ubuntu 12.04. I solved it by resetting pulseaudio user configuration as explained here.
You have to run the following lines in terminal
rm -r ~/.pulse*; pulseaudio -k
and then logout and log back in.
aecins
If you are referring to the problem that, You cannot select sound profile from the sound settings menu, then you can try the following method. I provided the answer in some questions. It works for me, so can also work for you.
Solution 1:
(It worked for me with Only S/PDIF profile, Sound from both headphone and speaker and not being able to switch profile)
  1. Add this ppa by the command
     sudo apt-add-repository ppa:ubuntu-audio-dev/alsa-daily
  2. Update packages list by
     sudo apt-get update
  3. Then install "alsa-hda-dkms" package:
     sudo apt-get install alsa-hda-dkms
Reboot, And See the result!
Solution 2
  1. Go to Realtek official site, accept the disclaimer, then download the audio driver for linux/unix. You need to select version 3 for Kernel 3 or later.
  2. Setup necessary tools to compile this driver.
    sudo apt-get install build-essential gcc make
  3. Extract the downloaded file, run sudo ./install file from a terminal after going to the extracted folder to compile the driver.
  4. Read the Readme.txt file for more information.
I had a problem with Sound settings in Ubuntu 12.04 (not being able to switch profile). It fixed now.
Anwar
  • 75,875
  • 191
  • 309
I have had this problem with 12.10 and looked all over. I finally found my answer here:
https://bugs.launchpad.net/ubuntu/+source/alsa-driver/+bug/864735
I modified /etc/default/grub, rebooted and voila!
Hope this helps.
Eric Carvalho
  • 53,609
  • 102
  • 137
  • 162
Rick B
  • Thanks for contributing this answer! It's generally helpful to quote the most relevant parts of a link (in this case, the instructions on the modification to make to `/etc/default/grub`) in case the target site is unavailable. – Andrew Johnson Dec 14 '12 at 23:50
In my case (Dell Latitude E4310 laptop) the problem was the following line in /etc/pulse/client.conf:
autospawn = no
I commented this out, and then ran
pulseaudio -k
and
pulseaudio
and then the sound icon in the taskbar came back to life, and the volume up/down/mute buttons started working.
StayOnTarget
  • 130
Install pulseaudio-module-udev
sudo apt-get install pulseaudio-module-udev
Martin Monperrus
  • 742
