I did a fresh Ubuntu 12.04 install on my Sony Vaio laptop, which worked perfectly with 10.04. Now my wireless won't work. I have read just about every Q&A on the subject and I have tried different solutions, including the official troubleshooting guides.
My laptop is equipped with a Intel 5100 wireless device. Ubuntu recognizes the device and it's status is given as connected in nm-tool. I can ping the gateway, my own IP number and localhost. Rfkill shows no soft or hard blocks.
  • I can ping 8.8.8.8. Average time is about 15ms.
Any ideas? I am just a few hours shy of reinstalling good old 10.04!
Jorge Castro
  • 70,934
  • 124
  • 466
  • 653
I have had a similar problem. However it was pointed out (on another forum) that the kernel has been updated and that I should look for an updated driver. My wifi is via a usb dongle so I got the update from Realtek's site.
Buntiphil
Please try:
    sudo modprobe -r iwlwifi
    sudo modprobe iwlwifi 11n_disable=1
Does it help? If so, write a conf file:
    gksudo gedit /etc/modprobe.d/iwlwifi.conf
Add a new line:
    options iwlwifi 11n_disable=1
Proofread, save and close gedit.
chili555
  • 58,968
  • 93
  • 129
