I will start by saying this is not a duplicate of System Program Problem Detected nor "System Program Problem Detected".
I do not want to disable apport. I want to find a way to know what is the Problem the system detected and find a way of fix it.
This notification appears everytime I log in: Saucy Salamander
I am using Ubuntu 13.10 Saucy Salamander 32Bit.
Edits:
1. Apport won't come up when clicking Report Problem.
2. Cairo-Dock won't start sporadically.
3. Login takes longer than expected.
4. Chrome crashes from time to time.
5. Laptop will overheat when CPU usage.
Hans
  • 1,251
  • When you click "Report problem...", apport will come up, and will be able to give you more in-depth information. Would you mind copying and pasting the output from apport, please? Keep in mind, it may take a few seconds for apport to get all of the information, so be patient. :) – ExplodingKittens Feb 01 '14 at 03:46
  • okay, that's fine, we can try to work this out without apport. Have you been experiencing any issues besides these errors appearing (eg. Unity crashes, programs crash, slow logout/login)? – ExplodingKittens Feb 01 '14 at 03:51
  • I have the same thing here. I'm on Asus N76W laptop, what is your machine? – v010dya Feb 01 '14 at 03:53
  • @Hans I have found that there are some issues with i5 processor on this machine, when it is running at 100% (no, not only heat sinking). BOINC, for example, produces invalid results. This is why i have asked. – v010dya Feb 01 '14 at 03:59
  • @Hans Chrome tends to crash quite a bit (I don't know if they fixed that in this most recent update), but since you are getting the error dialog at login, the culprit may be Cario-Dock. It might be crashing quite a bit, but catching itself most of the time and restarting. Other times it might not be so lucky. Consider uninstalling Cario-Dock with `sudo apt-get remove cario-dock`. If this doesn't solve the problem, you can reinstall it without having to redownload by simply issuing `sudo apt-get install cario-dock` again. – ExplodingKittens Feb 01 '14 at 04:01
  • Generally the system program problem detected pops up just after a application exits due to a bug.This is not always the case though.I will try to recreate some bug and then write an answer with necessary screenshots.For now,if you click **report problem**,it should show another window.Now click on the small arrows to expand report.You may see the application which caused the bug there somewhere.If you don't get me,don't mind,I'll try to write a good answer if I could recreate some bug. – Registered User Feb 01 '14 at 04:03
  • @Hans that's definitely not right. Try removing all programs with the prefix of "cario" by using `sudo apt-get remove cario*` – ExplodingKittens Feb 01 '14 at 04:19
  • @Hans if `sudo apt-get remove cario*` comes up with nothing, then yes, try `sudo apt-get remove Cario*`. I'm not completely familiar with the exact package names, and Linux has always been very case-sensitive when it comes to pretty much anything. – ExplodingKittens Feb 01 '14 at 04:22
  • @Hans oh, right, my bad. I tend to mispronounce/misread/miseverything that first word. :) – ExplodingKittens Feb 01 '14 at 04:31
  • @Hans right, that's why I had suggested removing any programs under `cairo*`. As for the package files, I believe that unless you issue `purge` in lieu of `remove`, the .DEB files remain on your hard drive for convenience purposes. – ExplodingKittens Feb 01 '14 at 04:58
  • Have you tried to see if any crash reports are exist in `/var/crash/` directory ? – NickTux Feb 01 '14 at 05:02
  • @Hans - please can you summarise the above rather lengthy comments by editing your question. Then you can delete your comments to cleanup. Thanks. – fossfreedom Feb 02 '14 at 09:55
Fixed by improving keyboard shortcuts in the Cairo-Dock app:
  • Corrected Lock Screen Shortcut as Super+L somehow is not allowed.
  • Corrected Use Keyboard to navigate Cairo Dock as Super+Enter is somehow not allowed.
Hans
  • 1,251
