I know that there are the 3 tabs at the top, and there is the preferences menu, but what can each of these sections mean? What is Control Group, and why is it blank? There are a lot of fields that I can select and I wanted to know what each of them was. For example, why are there lots of processes with the same name?
Also, what is the setting for bits and bytes? I'm quite confused by that, as the graph just shrinks, and the numbers at the edge get bigger when I change it.
This is a topic that is very sparse, not just here but in general on the internet - I have done a lot of research but a lot of it has been fruitless. there is documentation about lots of programs, but not this one.
I know that this is a fairly broad question in some ways, but in others it is quite specific. It isn't a duplicate - there is almost nothing about the system monitor on the internet, never mind just here.
Apologies if it is too broad, suggestions as to how to make it better are appreciated!
Tim
  • 32,274
  • 118
  • 177
This is a topic that is very sparse, not just here but in general on the internet. Please take any section of this to use in an answer - but a link back is appreciated :-)
Processes Tab
Process Name
The process name is the name of the process. Multiple processes can have the same name, but different process IDs. This is useful, as it means if you want to get rid of all your nautilus windows, you can execute a simple command:
pkill nautilus
and they will all be killed.
It can be sorted Alphabetically A-Z or Z-A.
User
This is the user that owns the task. By default, you can only see your own processes. To see those run by other users, click View (top, right hand corner) and then All Processes. Then it will show those owned by other users, including root.
% CPU
This shows the % of CPU being used by that process. By default it is divided by the CPU count (meaning if you have a dual core, and one process is using 100% of a single CPU, it will show up as 25%).
ID
The ID field shows the identification number of the process. This is a unique number for each process and the only way of identifying identically named processes reliably. This is useful when you want to kill a specific process, but it has others with the same name:
The process identifier (normally referred to as the PID) is a number used by most operating system to temporarily identify a process. This number may be used in a command, allowing processes to be manipulated, such as killing it altogether.
Memory
This is the amount of RAM being used by that process.
It is always rounded to 1 decimal place, but the units vary. If it is less than 1 GiB (1024 MiB) it displays in MiB. If it is less than 1 MiB (1024 KiB) it displays in KiB. Because of this, you never see 0.5MiB of RAM, it is always 500 KiB.
Priority
This displays the priority of the app - how much CPU it is allowed to use compared to other processes. There are 5 options - Very Low, Low, Normal, High, Very High.
An app running with higher priority gets more access to cpu time as compared to an app running with low priority. This is primarily used to keep an app (like the Arista transcoder) from eating all of the cpu time and slowing the system to a crawl, OR, for allowing one app to suck up as much CPU as it can regardless of the consequences.
Source
Status
This will either be Sleeping or Running. Most of mine are sleeping.
Virtual Memory
Virtual memory is a memory management technique that is implemented using both hardware and software. It maps memory addresses used by a program, called virtual addresses, into physical addresses in computer memory.
Source
This shows how much is being used by each process.
Resident Memory
This relates to physical memory.
Shared Memory
Amount of memory assigned to multiple processes.
Started
This is simply the time date started. This can be useful for seeing when you started an application, but also when you booted your machine up - if you sort it, typically there will be a whole load with an identical time at the top. That is pretty close to the time you turned it on (for this to be precise for the start up time, you have to have enabled See All Processes).
This can be sorted from Most recent to Oldest and Oldest to Most recent.
Nice
This is simply the Priority, expressed in a numerical format. It has more precise control over it (-20 to 19 has 40 options, where as Very How to Very High has 5).
'nice' refers to the priority the process gets on your CPU. This is a number in the range of -20 (highest priority) to 19 (lowest). You'll probably find that most applications you're running are at nice '0', which means that they are running with normal priority and none will get preferential treatment by the scheduler over another.
Source
Command Line
This is the command that is run to start the application. Typically it will display the path to the executabe file.
For example my processes named Chrome were all launched with
/opt/google/chrome/chrome --[someoptions]
Waiting Channel
The waiting channel is the place in the Kernel where the task is currently waiting. A task has to wait for resources, which can be data or processing time. Those include network sockets, hardware, files, and so on; since most of them are just files, in Unix-like systems.
Source
What is the "Waiting Channel" of a process?
Control Group
Google doesn't know, and this is completely blank for me so...?
Preferences Window - Processes
This is the preferences window on the processes tab. It has 2 main sections, Behaviour and Information Fields (Columns)
Update interval.
This sets how often it refreshes the data. It can be anything from 1 to 100, and it is in seconds. If you enter more than 100, it goes to 100, and less than 1 goes to 1. You can also chose a decimal, to 2 decimal places. It seems to allow any decimal (i.e. 1.32 doesn't change to 1.25)
Enable Smooth Refresh
I can't see any difference, however it may be to do with the animation of the processes, i.e. they slide, rather than jump?
Alert before ending or killing a process.
When enabled, when you try to end a process, this dialogue is triggered, to prevent accidental termination.
Divide CPU usage by CPU count.
This affects the % CPU field. When this is enabled, if you have a dual core, and one process is using 100% of a single CPU, it will show up as 25%. When disabled, it will show up as 100%.
This also affects the CPU graph on the Resources tab.
Information Fields
With this you can select which fields to be shown. By default only Process Name, User, %CPU, ID, Memory and Priority are shown.
Resources Tab
CPU History
This will show you the percentage of processing power being used right now, and for the last X seconds, per processor. The amount of time is shows for is dependant on the refresh rate. Each line displayed is one of your CPUs (if you have a Multi-core Processor). Each core has it's own trace.
Below the graph are boxes. They are coloured the same as the graph lines. The number of boxes corresponds to the number of processors you have. Clicking one will bring up a colour selection window. There are some default colours, and you can create a custom one. Next to each box is the percentage of that processor that is being used.
The top of the graph will always be 100%
Memory and Swap History.
This will show you the percentage of memory and swap being used now, and for the last X seconds. The amount of time is shows for is dependant on the refresh rate. A line is displayed for the Memory (Purple - AB1852 by default) and Swap (Green - 49A835).
Below the graph are segmented circles. The amount filed corresponds to the amount used. They are coloured the same as the graph lines. Clicking one will bring up a colour selection window. There are some default colours, and you can create a custom one. Next to each cirlce is the percentage of that resource that is currently being used. The centre of the circle is always coloured in, even if it is 0%.
Network History
This will show you the amount of data uploading and downloading right now, and for the last X seconds. The amount of time is shows for is dependant on the refresh rate. A line is displayed for the Receiving / Download (Purple - 2D7DB3 by default) and Sending / Upload (Green - EE1D00).
Below the graph are arrows. They are coloured the same as the graph lines. Clicking one will bring up a colour selection window. There are some default colours, and you can create a custom one. Next to each arrow is the amount being uploaded / downloaded right now. This can be used as a pretty accurate download speed tester. I normally run apt-get update to get a good measure. And below that is thr total Downloaded / Uploaded since the last restart.
The top of the graph will vary, from 10 KiB/s to 5 GiB/s, and the lines will never exceed it (unless they are higher than 5 GiB, which does happen when you disable and renable wired internet soemtimes. Instead, the top of the graph will increae, and the graph will be scaled apropriatly). The base is always 0 which means that if you have fast internet you can't see very accurately what it is (as the scale is large).
Preferences Window - Resources
This is the preferences window on the resources tab. It only has 1 main section, Graphs.
Update interval.
This sets how often it refreshes the data. It can be anything from 0.25 to 100, and it is in seconds. If you enter more than 100, it goes to 100, and less than 0.25 goes to 0.25. You can also chose a decimal, to 2 decimal places. It seems to allow any decimal (i.e. 1.32 doesn't change to 1.25).
This value is what determines X seconds (the amount of history displayed). The graph history can display at most 60 refreshes, so if you set it to refresh once every second, it will display history for the past 60 seconds - 60 refreshes. If however, you set it to refresh every 0.25 seconds, it will display history for the past 15 seconds - 60 refreshes. As a rule, it will display for updateinterval*60.
This value affects all the graphs.
Draw CPU chart as stacked area chart.
This affects only the CPU graph. It will change it from the line graph formatting to a filled area graph. I don't see the point, but someone who doesn't get computers says that it "Looks prettier", so it does have a use - entertainment.
Show network speed in bits.
A lot of people don't realise the difference between bits and bytes.
A bit is the basic unit of information in computing and digital communications.
Source
The byte is a unit of digital information in computing and telecommunications that most commonly consists of eight bits.
Source
So that means a 10 byte file is 80 bits. And a 1 KiB/s (1 kilobyte) internet connection is 8 Kbit/s (8 kilobits) (and useless). Because of this, you get a difference in how they are compared.
In reality, you have a MiB (Megabyte) connection, not a Mbit (Megabit). But, in order to make it look like more ISP normally advertise their speeds in Mbits. If we use my connection as an example - it is currently 680 KiB/s (which sounds quite bad, and, to be honest it is). But in Bits, it is 5.31 MBits/s. That sounds much better! (To convert between the two, just times the Mbits/s measurement by 8, then convert between KiB/MiB if necessary with * or / by 1024.
This feature lets you switch between which one you want. Most speed tests are in Mbits, so this can help confirm that.
File Systems Tab
This tab simply displays all of your file systems and details about them.
Device
This is the name of the device. When it has no name it displays as the mount point. So for example my HDD is called /dev/sda2
Directory
This is where the device can be accessed. So for example my HDD's Directory is /, and my external HDD is /media/tim/Big.
Type
This shows how it is formatted. So for example my HDD is formatted as EXT4 and my external HDD is fusebl (whatever that is).
Total
This shows the total size of the disk. So for example my HDD is 1.7 TB (Terrabytes - it used to 2 but it's been partitioned), and my external HDD is 500 GB.
Available
This shows the amount of free space on the disk. So for example my HDD has 852 GB free, and my external HDD has 71 GB
Used
This shows the amount used, and a graphical percentage (a bar with the % on it). So for example my HDD has 736 GB (46%) used, and my external HDD has 429 8GB (85%).
Preferences Window - File Systems
This has 2 sections, Behaviour and Information Fields.
Update interval.
This sets how often it refreshes the data. It can be anything from 1 to 100, and it is in seconds. If you enter more than 100, it goes to 100, and less than 1 goes to 1. You can also chose a decimal, to 2 decimal places. It seems to allow any decimal (i.e. 1.32 doesn't change to 1.25).
Show all file systems
When ticked this shows all file systems, not just the /dev/sd*X ones.
Information Fields
With this you can select which fields to be shown. By default all of them are shown.
That is a summary of all of the features of the software centre.
Tim
  • 32,274
  • 118
  • 177
    [Control groups](http://en.wikipedia.org/wiki/Cgroups) are usually called `cgroups`. They can be used to control some aspects of processes. Here's an example [usage of cgroups](http://askubuntu.com/questions/510913/how-to-set-a-memory-limit-for-a-specific-process/510936#510936) I posted recently. They're behind much of the power of `systemd` and `lxc`. – muru Aug 16 '14 at 19:34
    Regarding MB/Mb: When ISPs post connection speeds, they usually use SI units (Mega == 1000,000,000x) (just like storage manufacturers). So a conversion from megabit speeds to our usuall MB would be (x/8)*(1000/1024)^3. Also: There looks like a typo where you say 680 MiB/s when you probably meant 680 KiB/s? – muru Aug 16 '14 at 19:37
