In Ubuntu 13.10 and older there were a keyboard layout option "use keyboard led to show alternative layout", so I could use it to have caps lock LED indicating current keyboard layout.enter image description here Now there is no keyboard layout preferences. I tried to use gnome-tweak-tool, but there is no that option too. Also I tried to type in console:
setxkbmap 'us,ru' -option 'grp:ctrl_shift_toggle,grp_led:caps,compose:menu'
and add
XKBOPTIONS="grp:alt_shift_toggle,grp_led:caps"
to /etc/default/keyboard, but this doesn't work too.
aryndin
  • 250
Use
dconf write /org/gnome/desktop/input-sources/xkb-options "['grp_led:caps']"
But I have two notes:
  • until recently there was a bug where the LED stays always lit, disregarding keyboard layout. It was fixed today (disclaimer: I fixed it), and it will be part of Gnome 42 release.
  • You probably noted I omitted grp:alt_shift_toggle option. I advise against using it because that poorly integrated with gnome-shell and it conflicts with whatever keyboard layout switch shortcut is chosen in gnome-settings. In particular, I don't think per-window layout feature will work this way. And I certainly saw that a popup upon changing layout doesn't appear this way.
    Instead you should choose keyboard layout switch shortcut in Gnome settings manually.
Hi-Angel
  • 3,612
  • 29
