I'm using Teltonika RUTX12 dual LTE cat 6 router with two 4G sim cards. Each sim card give me around 16mbps of down-link which is to me very slow. While purchasing this unit I thought it comes with proper link aggregation but it only have simple fail-over and load balancing feature. like some of the peplink boxes do
So I'm trying to do this myself using two wireguard links and combine traffic with support of VPS. I found similar question in reddit this but I'm stuck with the PBR part.
Below are the steps I did so far
WWAN1 - LTE SIM1
WWAN2 - LTE SIM2
create two wireguard interfaces on same VPS with below config
wg0
[Interface]
Address = 10.22.22.1/24
ListenPort = 54837
Table = off
PrivateKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
PostUp = iptables -A FORWARD -i eth0 -o wg0 -j ACCEPT; iptables -A FORWARD -i wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
PostDown = iptables -D FORWARD -i eth0 -o wg0 -j ACCEPT; iptables -D FORWARD -i wg0 -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
### Client remote_gw_wg_1
[Peer]
PublicKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
AllowedIPs = 0.0.0.0/0
wg1
[Interface]
Address = 10.33.33.1/24
ListenPort = 54838
Table = off
PostUp = iptables -A FORWARD -i eth0 -o wg1 -j ACCEPT; iptables -A FORWARD -i wg1 -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
PostDown = iptables -D FORWARD -i eth0 -o wg1 -j ACCEPT; iptables -D FORWARD -i wg1 -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
### Client remote_gw_wg_2
[Peer]
Connect router to the VPS using two wireguard interfaces
wg0
[Interface]
FwMark = 100
PrivateKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Address = 10.22.22.2/32
[Peer]
PublicKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Endpoint = xxxxxxxxxxxxxxxxxx:54837
PersistentKeepalive = 20
AllowedIPs = 10.22.22.0/24
wg1
[Interface]
FwMark = 101
Address = 10.33.33.2/32
[Peer]
Endpoint = xxxxxxxxxxxxxxxxxx:54838
AllowedIPs = 10.33.33.0/24
After this I can ping to both wireguard interfaces from rutx12 to vps and vps to rutx12
Then I create route table called wireguard on /etc/iproute2/rt_tables
# reserved values
255     local
254     main
253     default
0       unspec
144     wireguard
# local
#1      inr.ruhep
Then I added two default route with equal metric to the new wireguard routing table
ip route add default dev wg0 table wireguard && ip route append default dev wg1 table wireguard
root@rutx12:~# ip route show table wireguard
default dev wg0 scope link
default dev wg1 scope link
Then I add ip rule all traffic not marked with fwmark 100 and 101 use routing table wireguard
ip rule add not fwmark 100 lookup wireguard priority 10
ip rule add not fwmark 101 lookup wireguard priority 10
Based on the reddit post I should add SNAT for get this working. But I'm not sure why SNAT needed. first I need to test aggrigated bandwidth within my rutx12.
Since the main routing table have default route to my WWAN01 link (sim1) how the wireguard utilize both the wwan links for traffic ? (both sim1 and sim2). Do I need to add static route for each? or do I need VPS with two public IP address ?
What are the things I'm missing here? and is there any other way to aggregate these two connections ?
rafalefighter
  • 187
    Did you read [LARTC split access](https://lartc.org/howto/lartc.rpdb.multiple-links.html) article? Much better Linux networking manual than how-tos on Reddit. Also it explains how to do load balancing. – Nikita Kipriyanov Nov 26 '21 at 06:49
    You said the router supports load balancing therefore you should enable that. Full Stop. You have two public IPs and and new outgoing connections will be balanced between them, but they won't *share* the Wan connections between individual connections. Nothing you do on your end will change that. If yiu have lots of devices you may benefit. If you have a small number of devices making a lot of seperate simultaneous connections you may benefit. If you have connections that are maxing out the available bandwidth and you'd like to increase this using the other Wan port that will not happen. – Blind Spots Dec 09 '22 at 04:20
  • I managed to do this with two Openvpn tunnels. Unfortunately, Wireguard being L3 not supported such bonding setup. Even with working Openvpn setup, Bandwidth not increased much. It did use both uplinks and speedup the single connection. but gain is not 2x. – rafalefighter Apr 16 '23 at 02:54
