I have a bash script that calls on R, and is mapped to a keyboard shortcut in my i3 config, like this:
bindsym $mod+q exec --no-startup-id test-r-not-working-from-within.sh
Here is a simple example that is easily verifiable, as it creates a file in /tmp/ with the ending '.testR' when the R session is successfully executed, and it also creates a file called test.testshell in /tmp/.
The script does run, as one can verify by the file created as /tmp/test.testshell, but the R session script that is supposed to run is not executed. When running the script from a terminal, however, the R session IS executed along with the shell commands.
#!/bin/bash
tmp1=$(mktemp)
echo '
library(data.table)
# troubleshoot
  tmp1 <- tempfile(tmpdir="/tmp", fileext=".testR")
  fileConn<-file(tmp1)
  writeLines("test this is a test", fileConn)
  close(fileConn)
' >> $tmp1
# none of these two ways of doing it works when called from i3
R  < $tmp1 --vanilla
Rscript $tmp1 --vanilla
echo 'test.testshell' > /tmp/test.testshell
notify-send "test-r-not-working-from-within.sh"
I was thinking it might be something with the $PATH, however, running gives:
which R
gives:
/usr/bin/R
So it should be in the PATH, right? Adding it manually to the PATH in my .bashrc profile does not do anything either, though:
export PATH="/usr/bin/R:~/.npm-global/bin:/usr/local/stata17:$HOME/.yarn/bin:$HOME/.cargo/bin:/home/emil/bin:/home/emil/.local/bin:$PATH"
I don't get it. Any ideas?
I'm on Manjaro Linux, fully updated.
emilBeBri
  • 121
