Not sure if this is the right place to ask such a question, but I don't see a more relevant place on stack exchange otherwise.
So recently I've become kind of obsessed with becoming more efficient with my usage of power when it comes to my computer, and the long term costs of running a computer via your power supply. and have recently been reading about the 80 plus standard.
anyway here is my question. I recently read the only way to really know how many watts your computer is pushing is to buy a kill-a-watt meter, which i did. I Actually bought the Ez version, which show costs including a number of other options.
At idle levels (CPU ~1-5%), my PC pushs ~100 Watts according to this meter. When i stress my computer to around 70-80% cpu levels, it pushs up to ~200 watts. This includes, browsing 3 or 4 heavy cpu driven websites, running a high end game in windowed mode, running a 10gb blu-ray movie and listening to music at the same time.
I'm really trying to understand why on earth people are buying power supply that are 600, 850 or even sometimes 1000+ watt. Can one of you electrical genius's explain this to me?
My computer Specs:
Other Specs: 1 - 128 GB SSD, 2 TB Green WD Hard Drive, 1 TB Hard Drive, 1 Optical Mouse, 1 Usb Keyboard, NO CD-Rom, 430 Watt Thermaltake
Chenmunka
  • 3,228
  • 29
  • 38
Outdated Computer Tech
  • 2,724
  • Did you read this about choosing power supply? http://electronics.stackexchange.com/questions/34745/choosing-power-supply-how-to-get-the-voltage-and-current-ratings – travisbartley Sep 12 '13 at 02:24
  • sorry, your link is like a general response to any power supply, im trying to get a simple answer for Computer power supply in terms of watts. –  Sep 12 '13 at 02:30
  • So it doesn't answer your question because it is not simple enough? What exactly were you confused about in that answer? – travisbartley Sep 12 '13 at 02:32
  • This might be more appropriate then. http://www.pcworld.com/article/2025425/how-to-pick-the-best-pc-power-supply.html – travisbartley Sep 12 '13 at 02:43
  • awesome downvote. 1. where does this post discuss watts? no where, 2. that post talks about 1 power supply for 1 device. a computer has 1 power supply for many devices. Your quick response, to throw me to a post that was posted a year ago to answer all related power supply questions, in my opinion doesn't apply to my situation, can you just turn off your ego for like 5 mins, and maybe someone can actually help me, and please don't edit my question, i took alot of time to take screenshots and post them, thank you. –  Sep 12 '13 at 02:43
  • I edited your question because more than half of it is irrelevant to the question being asked, and downvoted for that reason. If you need the discussion in terms of watts, then understand v=ir and p=iv. – travisbartley Sep 12 '13 at 02:46
  • do you actually have an answer to share travis? cause i've already read that artical. or do you have 4 more links to send me to cause you're too lazy to give me an answer? –  Sep 12 '13 at 02:47
  • I am gauging how much you have researched the answer yourself, which seems to be 0 as many sources have already answered it clearly and thoroughly. Why should anyone answer you when the knowledge is readily available? – travisbartley Sep 12 '13 at 02:49
  • Travis i know this question is beneath you according to your attitude and general manor toward my "silly question." but yes i have read that article and many others, and I've seen inconsistencies. I've went out of the way to buy a watt meter to get accurate results because 'power supply calculators' are apparently "false readings", and to ask this silly question to get and a 2nd opinion from a professional that has experience in the field. and thank god i got you. another troll that sits on his computer acting superior to everyone else over the web because the question isn't at his "level" –  Sep 12 '13 at 03:15
    I am confused as to what you're asking. Is your question about how to reduce the amount of energy wasted by your power supply? Or is your question about why people buy power supplies with output (watt) ratings higher than the normal load of the computer? – Li-aung Yip Sep 12 '13 at 03:20
    It is important to be able to take constructive criticism without getting upset. I have pointed out the problems with the question, and since you refuse to amend or address them this question will inevitably be downvoted until it is ultimately put on hold. – travisbartley Sep 12 '13 at 03:22
If your question is "Why do people buy large power supplies?" then there are a few reasons.
Their power requirements could actually be that high
Your computer has fairly modest power requirements. Power requirements are mostly driven by the CPU and GPU. Your i5-2500K CPU has a maximum TDP (thermal design power) of 95 W, and your nVidia GTX660 has a TDP of 140 W. Given your particular hardware it's not surprising that you observe 200 W as the maximum load. A 300 W or 450 W power supply would be quite adequate.
However, other people's computers can have much higher power requirements. A computer with a 150 W CPU and 2×250W graphics cards will need at least 650 W, not including the disk drives, USB devices, fans, water cooling pumps, LED lights (...) also drawing power from the power supply.
Such a computer would generally be equipped with a power supply in the 800-1000 W range.
They are purposely buying a bigger power supply than they need
Even if the computer's power requirements are only (ex.) 300 W, some people would go out and buy a 600 W power supply for it anyway.
The reasons they perceive this might be a good idea include:
  1. To allow some headroom for future upgrading of the computer - new parts might need more watts.
  2. So that the power supply will run at a lower temperature. Components degrade faster at higher temperatures, so the power supply is less likely to fail.
  3. To run the power supply at a higher efficiency. A power supply run at 100% of rated load is actually less efficient than a power supply run at 80% of rated load.
Li-aung Yip
  • 558
  • well i'm about to add 4 2-TB hard drives to the rig, and decided to go with this power supply. http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013 any thoughts? – Outdated Computer Tech Sep 12 '13 at 17:51
    Yes, but a power supply running at 20% is less efficient than 50%, so getting an 800 watt supply when you only need 200 will leave you with more heat and a larger power bill than a 500 watt supply. – psusi Sep 12 '13 at 18:25
  • @psusi: You're correct - I neglected to mention this because the answer was already getting too long. – Li-aung Yip Sep 12 '13 at 18:56
    @Sickest: We don't do shopping recommendations on this site - see http://superuser.com/help/on-topic . – Li-aung Yip Sep 12 '13 at 18:58
  • im not talking about shopping recommendations, you said a 450w would do the job. im asking about the 4 extra hard drives, do you think the amount of watts would do the job if i bumped it up to 550w. – Outdated Computer Tech Sep 12 '13 at 19:11
  • @psusi so getting a 550 watt supply would be ideal in my situation, also considering its a 80+ bronze. – Outdated Computer Tech Sep 12 '13 at 19:15
    Your question as originally posted was about *general reasons* why people would want to buy big power supplies. If you now have a separate question about what power supply you need for your specific needs, *post a new question*. – Li-aung Yip Sep 12 '13 at 19:17
  • i'm just asking about your opinion now regarding my situation, i'm not going to create another question just for that, i've already ordered the power supply anyway. – Outdated Computer Tech Sep 12 '13 at 19:19
First off, a lot of people buy into sales BS that a bigger power supply is better, and, of-course, promises you can expand it more. I think a lot of people also think that a power supply will just draw what it needs, and don't realise the overhead (again, this is a subjective opinion, and won't hold true of anyone who has even bothered to learn what "80+" means.
Another part of the puzzle is that people who haven't built a lot of systems generally don't know how much power a system requires, and its easier to buy a bigger supply then work it out - and still be wrong.
There is also some truth that buying a bigger power supply (can) mean the components are specced to handle greater current and thus will last longer, similarly they are able to better handle transient changes in input power (ie have a bigger power buffer for sudden draws).
Of-course, very often a smaller, high quality power supply will actually do much better then an overly large power supply.
davidgo
  • 68,623
  • 106
  • 163
  1. In your experiment you probably didn't hit the maximum possible power consumption of your PC yet. A high-end game might no put your GPU under full load, if you want to determine the maximum power consumption of your GPU you should try a program like FurMark (this program can damage certain older GPUs, so be careful).
  2. Yes, many power supplies are larger than they have to be. Higher numbers are generally better for marketing, so that could certainly a driving factor behind this. Many people also don't have a realistic estimate of how much power their computer will draw, so they'll get something bigger just to be sure.
  3. The supply of lower rated power supplies is rather limited, and there is not a large price difference between lower rated and higher rated power supplies in many cases.
  4. If you put in a lot of high-end GPUs, you might actually need that much power. A high-end GPU can draw around 250W, so with a few of them you could actually need a 1000 W power supply.
Mad Scientist
  • 1,093
Every power supply on the planet, be it an electrochemical battery, solar cell, or ATX PSU, has an internal resistance.
Every load on the planet, be it a light bulb, a water pump, or a computer, also has an internal resistance. As the current requirement of the load increases, its resistance necessarily decreases.
Putting Kirchhoff's circuit laws together with Ohm's law means that the voltage supplied to the load will decrease, at a ratio equivalent to the two internal resistances. Eventually the voltage may drop too low to operate the load properly.
Supplies with a higher power rating must, according to Ohm's law, have a lower internal resistance in order to be able to provide more current and therefore power. This lower resistance tips the voltage back up towards the "true" voltage of the supply, allowing larger loads to operate properly.
Ignacio Vazquez-Abrams
  • 111,361
  • 201
  • 247
