I recently installed Ubuntu 18.04.1 LTS from Windows 10. After installation system is not detecting any Wifi it says no adapters available. But when connected through LAN cable the internet works.
I tried couple of things but nothing helped.
rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
lshw -c network
WARNING: you should run this program as super-user.
*-network
description: Ethernet interface
product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 05
serial: b8:ca:3a:c3:5e:d2
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.0.9 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:16 ioport:2000(size=256) memory:c0404000-c0404fff memory:c0400000-c0403fff
*-network
description: Network controller
product: BCM43142 802.11b/g/n
vendor: Broadcom Limited
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 64 bits
clock: 33MHz
configuration: driver=bcma-pci-bridge latency=0
resources: irq:17 memory:c0500000-c0507fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Please help!
