Each time I reboot Ubuntu 19.10, I have to open gnome-control-center and set the sound output device back to my Laptop's Built-in speakers. Otherwise, it will typically default to DisplayPort devices that don't even have speakers.
Which file are these settings saved to? I'm thinking that maybe that file is corrupted and that if I delete that file maybe Ubuntu 19.10 will start remembering my sound output preferences. I'm also open to other suggestions.
Lonnie Best
  • 2,174
  • 32
  • 42
    Sébastien Bacher informed me that this is a known [bug](https://bugs.launchpad.net/ubuntu/+source/pulseaudio/+bug/1847570). – Lonnie Best Nov 11 '19 at 14:03
I have had the bug report suggestions setup this way for along time as sound is always routed to TV and I don't want it to switch to tinny laptop speakers.
Use sudo -H gedit /etc/pulse/default.pa and find the lines:
load-module module-switch-on-port-available
load-module module-switch-on-connect
Change them to:
#load-module module-switch-on-port-available
#load-module module-switch-on-connect
Save the file and use: pulseaudio -k
Note 1: It's been reported that plain sudo now performs like sudo -H in 19.04 but caution dictates using later method.
Note 2: Earlier versions of Ubuntu will only have the first configuration line.
WinEunuuchs2Unix
  • 99,709
  • 34
  • 237
  • 401
    The downside of this patch is that plugging in headphones or bluetooth speaker no longer switches automatically. – jII Jul 11 '20 at 00:23
