I am using ubuntu 18.04 on Acer Predator Helios 300 PH-315-51, every time my system boots up it prompts me with a message System problem detected i noticed it is actually due to the auto drive mount at startup, if i disable auto drive mount then it does not prompts me with this message, i don't know why is this happening. Can anyone please explain why is it so and how can i fix this issue ?
Asked
Active
Viewed 187 times
ayaankhan98
- 3
- 1
Try sudo rm /var/crash/*. This will clear all the crash reports if there are any. If this does not solve the issue try reviewing the logs.
Here, is a reference with a similar problem:
Mansoor Ahmed Memon
- 160
- 3
- 15
