20
I've been getting an issue since upgrading to 2.6.39 in Natty from the Kernel-PPA repository.
When I do a sudo update-initramfs -u I get the following error message.
update-initramfs: Generating /boot/initrd.img-2.6.39-0-generic-pae
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for module r8169
I did notice that firmware wasn't in the allocated directory. Does anyone know where to get the firmware files for this.
N.N.
  • 17,939
  • 92
Dean Thomson
  • 1,095
9 Answers9
42
Do sudo apt-get install firmware-realtek and the problem should be solved
Marco Ceppi
  • 47,783
  • 172
  • 197
Alex
  • 431
  • Is this a real package? On my 11.04 system, `apt-cache show firmware-realtek` returns a message saying the package doesn't exist. – djeikyb Aug 10 '11 at 00:53
    This package is in the Debian repos - it is not in the Ubuntu repos - so the answer is only applicable to Debian not Ubuntu. – fossfreedom Oct 24 '11 at 19:37
    You will also have to add access to the non-free repositories. Debian 9 guide: http://blog.programster.org/debian-9-install-raeltek-firmware – Programster Sep 09 '17 at 09:01
12
There's a solution at http://www.davidgis.fr/blog/index.php?2011/05/06/800--resolu-solved-w-possible-missing-firmware-lib-firmware-rtl_nic-rtl8105e-1fw-for-module-r8169. Essentially you need to do:
git clone git://git.kernel.org/pub/scm/linux/kernel/git/romieu/linux-firmware.git
sudo cp -r linux-firmware/rtl_nic/ /lib/firmware/
and then sudo update-initramfs -u works without errors.
N.N.
  • 17,939
  • 92
rocko
  • 136
I had the same problem whit Ubuntu 12.04.5 LTS. Today I have tested, but the old "git://git.kernel.org/pub/scm/linux/kernel/git/romieu/linux-firmware.git" is a broken link.
I have searched the new git url for dowload the firmware of realtek. The commands that I have tested (and works very well) are:
git clone git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
and
rm -rf linux-firmware
For deleting the directory that git has downloaded.
user471101
  • 61
Perhaps a better answer is to install linux-firmware package and if necessary linux-firmware-nonfree package.
N.N.
  • 17,939
  • 92
Recently I have faced the similar issue, but when I have followed the Rocko method, the link is broken. So it was not making it download the linux-firmware.
Also I have tried to do: sudo apt install firmware-realtek, still it didn't worked out.
After searching it online, found a new link of git. git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
Steps to follow:
  1. Download the linux-firmware: $ git clone git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
  2. copy the missing firmware to /lib/firmware: $ sudo cp -r linux-firmware/rtl_nic/ /lib/firmware/ $ sudo cp -r linux-firmware/i915 /lib/firmware/ (In my case i915 was also missing)
  3. update the initramfs: $ sudo update-initramfs -u
Note: After update, if still see that, some of the firmware are missing, then search it in linux-firmware and copy those folders into /lib/firmware.
Terrance
  • 39,774
  • 116
  • 176
Rajesh
It seems that the linux firmware package is corrupt, I solved this issue in ubuntu 13.04 by
sudo apt-get purge linux-firmware
and
sudo apt-get install linux-firmware
user204587
For Debian, I run the following command, and it really works:
apt-get install linux-firmware-nonfree
ECL
The file /lib/firmware/rtl_nic/rtl8105e-1.fw is in the package firmware-realtek
You need to run following command. Open terminal Ctrl + Alt + T :
penreturns
  • 5,940
MeTo
for me my server have rtl8125a but the firmware-realtek package do not include it. but I found it in kernel site; so this is how I solve it:
wget --quiet https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/rtl_nic/rtl8125a-3.fw
mv -f rtl8125a-3.fw /lib/firmware/rtl_nic/
update-initramfs -u
Badr Elmers
  • 141
