35
Sorry if this question is already answered, but I have already searched and could not find a solution to my problem.
Recently I installed gnome-shell and ubuntu-gnome-desktop to try gnome. I then removed it using
sudo apt-get remove gnome-shell ubuntu-gnome-desktop.
From that moment I couldn't change my desktop wallpaper. Also, when I right click on my desktop it doesn't work.
I read in some links to check if xfdesktop is running... In my ubuntu, that process is not running. When I run xfdesktop from terminal, it gives me the following error:
SESSION_MANAGER environment variable is not defined. Failed to connect to session manager.
I don't know if it has any relation to my problem.
Another thing I observed is that gnome-system-monitor and gnome-session are still running on my ubuntu... why are they running if I want Unity only?
Is there any way to reset my ubuntu to as it was initially. But I have also installed some useful applications and packages in this, can I keep them even after resetting?
Thank you in advance!
edwinksl
  • 23,569
  • 74
  • 100
user3903448
  • 521
  • I think this is a duplicate of or at least very similar to [287571](http://askubuntu.com/questions/287571/desktop-shows-a-white-or-black-background-instead-of-wallpapers) Gnome-shell disables Nautilus handling the desktop and so on Unity no wallpaper and no destop-icons are available anymore. – Christian Sep 23 '14 at 08:14
  • Thank you @Christian, this started changing the wallpaper. But Still right click and super key is not working when I am at Desktop. – user3903448 Sep 23 '14 at 11:24
  • Is Gnome-Tweak-Tool still installed? There is an option to let Nautilus handle the desktop. This must be set. According to the second answer to the mentioned question, this can also be done with "ubuntu-tweak-tool" which I do not know. – Christian Sep 23 '14 at 12:28
  • I think this might help you: http://askubuntu.com/questions/140944/i-cannot-right-click-on-the-desktop/141086#141086 – Saman B. Feb 03 '15 at 18:54
  • The gnome tweak tool did it for me, the option was already set, I just toggled it and it started working again. I not have backgrounds and can right click – Keith Jun 07 '15 at 07:16
I had the exact same problem.
Tried everything in the book!
This is what worked for me.
Hope your problem is solved soon.
gsettings set org.gnome.settings-daemon.plugins.background active true
Karan
  • 851
    Worked !! But what was the reason? I didn't get it. – Chaitanya Chandurkar Jul 02 '15 at 00:28
  • @Karan: I agree--what's the rationale here? – jvriesem Feb 27 '16 at 20:57
    This solution gave me back my changing wallpapers, but didn't allow me to click. This fixed the clicking problem for anyone that needs it: https://askubuntu.com/questions/142247/why-doesnt-right-click-work-on-my-desktop – The Unknown Dev May 07 '16 at 14:27
    Worked for me on Ubuntu 16.04.2. It's bizarre how something basic like this could be broken out of the box... – Pupper Jun 06 '17 at 02:05
  • also worked! I had variety installed, and it wasn't working. I am very curious how this isn't a default setting. Still no context menu on a right click, but I never really used it anyway. – Nelson Jul 12 '17 at 19:14
  • Worked nicely for me as well! I suspect this might have happened when I used the gnome-tweak tool to disable desktop icons. Anyone else who had this issue disable desktop icons via command line? – Christopher Kuttruff Apr 06 '18 at 06:50
After installing or removing of ubuntu-gnome-desktop a bug of Desktop not responding to clicks/icons can occur, You may reactivate:
Active Desktop Background:
Active Desktop Icons:
gsettings set org.gnome.desktop.background show-desktop-icons true
Benny
  • 4,790
Use the gnome-tweak-tool. Click the Desktop button (left side) Set:
Mode = Scaled
Background Location = ...image path
This happened to me too after I installed Gnome-Shell. Uninstalling it and rebooting restored the desktop clickability and brought back the desktop icons too.
ccpizza
  • 1,422
