I have a HP Pavillion dv6000 with Ubuntu 14.04 LTS and a Broadcom wireless card (BCM4312).
My Ethernet connection is fine. But when the wifi is turned on, it will stay connected for a short time and then disconnect and reconnect again. The wireless card is supposed to use the b43 driver, but it still does not hold the connection.
How can I fix my WiFi problem?
ByteBOT
  • 164
Ted Tarant
Using the ethernet temporarily, please open a terminal and do:
sudo apt-get install firmware-b43-installer
sudo apt-get purge bcmwl-kernel-source
Detach the ethernet, reboot and tell us if the wireless is working as expected.
chili555
  • 58,968
  • 93
  • 129
