I've been trying to find a solution for a problem I've been having with my laptop on 16.04 LTS for a few days now. I can only get the wifi to work after coming out of standby by typing these 2 lines which,as far as I know,reloads the driver for the wifi pcb:
modprobe -rf rt73usb
modprobe -v rt73usb
I've tried a few methods to try and get this to happen automatically.One was from this thread which gave me this:
!/bin/bash
case "$1" in
thaw|resume)
sudo modprobe -rf rt73usb
sudo modprobe -v rt73usb
esac
exit $
I put this in a file called wakenet, details:
ls -al
drwxr-xr-x 2 root root 4096 nov 27 16:48 .
drwxr-xr-x 5 root root 4096 ago  5  2015 ..
-rwxr-xr-x 1 root root  210 giu 26  2015 10_grub-common
-rwxr-xr-x 1 root root  660 dic  6  2013 10_unattended-upgrades-hibernate
-rwxr-xr-x 1 root root 1260 mag 23  2012 novatel_3g_suspend
-rwxr-xr-x 1 root root  112 nov 27 16:48 wakenet.sh
Please could someone tell me where I'm going wrong because when coming out of standby I still get the same problem? I've only got the basics of what's happening so if you could help I would greatly appreciate it.I guess I've made a fundamental error with the script?Cheers.Mark
ps some more info:
 lshw -c network
  *-usb DISABLED
       description: Wireless interface
       product: 802.11 bg WLAN
       vendor: Ralink
       physical id: 3
       bus info: usb@1:3
       logical name: wlx0019db03e22d
       version: 0.01
       serial: 00:19:db:03:e2:2d
       capabilities: usb-2.00 ethernet physical wireless
       configuration: broadcast=yes driver=rt73usb driverversion=4.4.0-47-generic firmware=1.7 link=no maxpower=300mA multicast=yes speed=480Mbit/s wireless=IEEE 802.11bg
  *-network
       description: Ethernet interface
       product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 5
       bus info: pci@0000:06:05.0
       logical name: eth0
       version: 10
       serial: 00:03:0d:5b:75:87
       capacity: 100Mbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
       resources: irq:16 ioport:2000(size=256) memory:b0200000-b02000ff
output of lsusb:
Bus 001 Device 002: ID 0db0:6877 Micro Star International RT2573
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  • Can you please check this thread http://askubuntu.com/questions/226278/run-script-on-wakeup – Bidyut Nov 27 '16 at 17:34
  • @Bidyut Tried that but couldn't get it to work.My script was:#!/bin/bash case "$1" in thaw|resume) sudo modprobe -rf rt73usb sudo modprobe -v rt73usb ;; *) ;; esac exit $ I put this in an executable file in this location /usr/lib/pm-utils/sleep.d .Is the above ok? – user620334 Nov 27 '16 at 19:55
  • Not sure if I understand @Bidyut.The above that I mentioned was in the executable file.Although it's difficult to read. – user620334 Nov 27 '16 at 21:29
  • Ya, you need to put it inside the `/usr/lib/pm-utils/sleep.d` if you are using Ubuntu 14.04, if you are using Ubuntu release greater than 14.04. – Bidyut Nov 27 '16 at 21:42
  • Yes,that's what I've done @Bidyut,put an executable file,with the above script,in the folder /usr/lib/pm-utils/sleep.d .I'm using 16.04 . – user620334 Nov 27 '16 at 22:21
  • Then you need to implement the resume script for systemd. Regarding that it has been described in the thread. I have not used 16.04 so I don't know much about systemd – Bidyut Nov 28 '16 at 05:10
Many thanks @Bidyut ,that was it!From this I did the following:
sudo touch /lib/systemd/system-sleep/wakeup
sudo chmod a+x /lib/systemd/system-sleep/wakeup
sudo gedit /lib/systemd/system-sleep/wakeup
then used the following script:
#!/bin/sh
case $1/$2 in post/*)
    modprobe -v rt73usb
esac
Also thanks to @Spmp
