Power supplies for ham radio equipment (and other equipment of course) seem to come in two flavours: switching and linear. The switching gear tends to be cheaper and smaller as well as more efficient.
My understanding is that switching supplies are more prone to creating RFI, but otherwise there is not much functional difference.
Is that the gist of it, or is there more? From the user's perspective, what is the advantage of one versus the other?
    I am currently finding that a significant percentage of the cheaper switching power supplies found in LED light bulbs (including LCD backlighting), USB power adapters and wall warts in my building radiate a significant amount of broadband RF noise. – hotpaw2 May 17 '18 at 15:24
The only reason to use a linear power supply is to reduce electrical noise (or if as an exercise in electronics you want to build your own power supply without using integrated circuits, or if you need your equipment to double as doorstops).
It is also quite possible that if you do want to reduce noise, you will be better served by adding filters to, or upgrading, other power supplies in your house than by choosing a linear supply for your transceiver. (For example, my apartment's HF noise level went from useless to tolerable by winding the DC cables for my internet equipment (cable modem and WiFi AP) several turns around ferrite cores. The noise from the Alinco switching supply I run my transceivers from is unnoticeable compared to everything else.)
Details on some of the factors:
  • Noise. A switching power supply inherently generates high-frequency signals as it, well, switches. The frequency and power of the noise that is seen at DC output — or the air — depends on the design of the supply. Many cheap switching power supplies as seen in consumer electronics will radiate significant noise compared to one recommended for amateur radio use.
    Naively looking at the typical noise frequencies (in the kHz) suggests that this noise may be a problem for HF operation but not typically for VHF, and this is generally true, but remember to consider any intermediate frequencies used by your gear, and also the possibility of interference with AF signals (such as your microphone).
  • Efficiency. A linear power supply inherently wastes some energy — it takes the (usually) AC line voltage, reduces it to an unregulated lower voltage (still higher than the desired output) with a transformer, rectifies it, then regulates it precisely using a linear regulator. A linear regulator is effectively a variable resistor in series with the output that “drops” the excess voltage — generating heat. Therefore, linear supplies generate lots of heat and require large heat sinks. Switching supplies still generate heat since they are not made of nonexistent ideal components, but much less.
    If your “ham shack” is not air-conditioned, you will directly appreciate the efficiency of a switching power supply.
  • A switching power supply can operate at a much larger range of input voltages. This doesn't mean just not having to pick 110V/220V; it also means that it can compensate for significantly lowered input voltage by drawing more current from the input, whereas a linear power supply will stop regulating because the fixed transformer ratio produces too low a pre-regulation voltage. This is usually not that relevant.
  • Size and weight, obviously enough.
Kevin Reid AG6YO
  • 24,195
  • 48
  • Thanks. So in short, switching is the way to go, as long as its negative characteristics (principally potential for RFI) aren't causing any harmful effect on the operations a ham wants to conduct? – Jim MacKenzie VE5EV May 16 '18 at 22:24
  • Well, you'll find that the efficiency differences don't matter at all for very small currents, and that switchers are actually *hard* to completely silence. So, it really depends. – Marcus Müller May 16 '18 at 22:30
    @JimMacKenzieVE5EV Yes. I've added a summary to my answer saying so, and also I thought of another thing to mention: poor switching supplies that are _not_ your transceiver's supply may be of more concern than choosing linear or switching. – Kevin Reid AG6YO May 16 '18 at 22:43
  • One more noise to consider is fans. Many higher power switching supplies have fans while many linear supplies (e.g. the most popular ham brand) do not. – Glenn W9IQ May 17 '18 at 10:13
You've pretty much hit the nail on it's proverbial head:
Both are power supply architectures, and as such generally fulfill the role of providing a constant-as-necessary voltage source (or current source, for some applications, but we're most likely talking about voltage sources).
Now, you can imagine a linear power supply simply as a self-adjusting resistor. It adjusts its resistance exactly as much as to drop enough voltage so that the voltage between its output terminal and its ground terminal is constant.
Of course, that means that $V_{drop}\cdot I_{output} = P_{wasted}$, i.e. all that voltage drop is waste heat. You hence simply can't do that for overly large voltage drops or overly large currents, because things get hot. Things getting hot means you need beefier voltage regulator ICs and larger heat sinks. That's expensive. For large voltage drops, and security critical things, you simply can't do that, because no (affordable) semiconductors exist that support both the power and sufficient isolation.
Now, a switch-mode power supply works by having an energy storage from which it takes small portions of energy. In a typical topology, this means that you have your input voltage over a coil, which of course starts to build up a magnetic field. Then, you switch the in- or the output off and on again, to bring the voltage across that coil onto your target output voltage. The energy taken by the output in shape of current is taken from the coil's magnetic field, so that the amount of switching on and off needs to accomodate the target voltage and the amount of current drawn, and the fact that a higher input voltage can "recharge" the coil faster.
With a bit of cleverness, you can, that way, even step up voltage! Something that's impossible to do with linear power supplies.
If you look at the power wasted, there theoretically is zero: energy is just being converted from input electrical current to magnetic field and back to output current at a different voltage, and all these processes are theoretically lossless.
In practice, you of course get the resistances in your coil's wires and the losses in the coil's core as well as resistances in the switch (typically, a transistor), so things are maybe 80% to 98% efficient – but that's way, way more efficient then let's say converting 1A of current from 12 V to 5V:
With a linear supply $I_{out}=I_{in}$ (plus losses), so $P_{in}=V_{in}\cdot I_{in}=V_{in}\cdot I_{out} = V_{in}\frac{P_{out}}{V_{out}}=\frac{V_{in}}{V_{out}}P_{out}$, with a switch mode supply $P_{out}=P_{in}$, only! Which means that the linear supply scheme uses $\frac{12}5=2.4$ times as much power!
Regarding noise:
Of course, switching necessarily means that you switch a current on and off, and you'll see that on the output side of your coil, as ripple. Typically, a smoothing capacitor takes the job of reducing that ripple to a degree sufficient for the electronics supplied to work.
However, reducing doesn't mean getting totally rid of, and you'll need to design a smoothing stage that fits your need: if your need is just driving a microwave oven's clock display, ripple-rich (hence, noisy) output voltage doesn't matter to you at all. If you're trying to pick up some weak transmission on a frequency close to the frequency your switch mode supply works at (or one of its harmonics), you'll have a harder time.
In professional lab and SDR equipment, which still often is cost-, size- and power-restricted, you'll often actually find a cascade of power supplies; for example:
A set of switchers to step down the 6 to 9 V (which usually comes from a switch-mode "wall wart", converting grid to something safe for humans to touch) input to 5 V, 3.3 V and 1.8 V; the last voltage to be converted to 1.2 V through a low-drop linear supply for the high-speed digital logic and memories, 3.3 V for direct usage by the digital interface ICs, which don't care about noise nor very exact voltage overly much, and 5V to be regulated with another set of linear supplies for all the analog signal chain, with plenty of RC low pass filters in between the switching power supply, the linear regulator, and if small and constant current draw allows, between linear regulator and the device (amplifier, mixer, adjustable attenuators, microwave switches...).
Marcus Müller
  • 15,225
  • I don't get it. I thought a transformer would step up voltage from a linear supply. Is that then not considered part of the supply or what? – davidbak May 17 '18 at 04:19
  • A transformer can be part of the supply, but it can only transform AC power from one voltage to another. After it is rectified to DC, the transformer can't help. – user10489 Jan 05 '20 at 01:02
-4
I have a 35 amp Astron linear supply and the heat generated at 25 watts is negligible. So I beg to differ with the answer that linear power supplies run hot.
KZ4ZK
  • 25 watts would be only 1.8 amps at 13.8 VDC. Are you speaking of a 25 watt *continuous* DC load? That's probably what my IC-765 transceiver draws on receive, and yes, it just runs warm. However, at 20A output (100W output CW, FM, digital, RTTY, processed SSB, etc. *especially in a contest*), those 4 pass transistors and their heat sinks on the back of my linear Astron PS get up to my definition of hot. – Mike Waters Dec 25 '19 at 21:35
    Answers should address the original question, not merely comment on another answer. Please consider editing your answer to compare switching and linear supplies, or deleting it. – Kevin Reid AG6YO Dec 25 '19 at 21:57
