I am looking for a communication solution with the following requirements:
  • wireless
  • unidirectional, point to point
  • low power (li-ion battery powered, should operate at least one hour on the single charge)
  • low baudrate data transfer (cca 40 - 80 bauds)
  • long distance, in the terrain covered by the forest, behind the small hill. One km sholud be enough but more is better
  • using free band within EU
What technologies should I check? Are there any existing modules for this? I would like to connect it to Arduino.
RFM12B or RFM69CW sounds like what you want. Operates in the ISM band. There's sketches available for Arduino and with a decent yagi antenna you should be able to reach that far.
captcha
  • 1,094
  • Thanks. And what about http://www.seeedstudio.com/depot/420450MHz-Ultra-low-power-data-radio-module-p-2209.html or http://www.hoperf.com/upload/rf_app/HM-TRP.pdf? – Martin Ždila Dec 03 '15 at 21:37
  • Go for it! They're both 100mW and the HopeRF seems cheaper and more frequency-agile. A suggestion: I would not even use a feedline but connect the radio directly to the antenna. At these low power levels you want to keep losses to a minimum. – captcha Dec 03 '15 at 22:29
The LoRa standard use spread spectrum technology, provides 20 to 30 dB improvement over traditional modes, when configure at the type of low speed that you require.
Some test documented on web shows 20km using 0.1 watt. These chip work at Global bands, EU, US ISM, 430, 8xx and 9xxMHz
The Adafruit sites as full tutorial for two Arduino libraries
Sigfox is a competing standard, using ultra narrow band
Adafruit hopeRF
EEd
  • 562
For such terrain I guess something in lower frequencies would do better. There are some cheap wireless serial radio modules for Arduino that use 433 MHz.
Other viable solution is xBee, but it uses higher frequencies, and it is more expensive.
Pedja YT9TP
  • 870
There are some type of NRF24L01 that are long range 3km+ rated. With a wifi amplifier (it works at 2.4GHz) you could also reach bigger distances.
