12
I'm going to buy a new SD card to be used in my car's audio player. What I would like to know is, if I buy a micro SD card with adapter, will it provide the same read/write speed as a standard SD card of the same model? Does using adapter affect speed?
Mehper C. Palavuzlar
  • 55,164
  • 49
  • 193
  • 250
The adapter is basically just a bunch of wires; they use the same signaling. The class of the device will determine the speed, not the adapter.
Ignacio Vazquez-Abrams
  • 111,361
  • 201
  • 247
As far as my experience goes, there's no difference between using an SD card vs a micro SD card.
I've even booted full linux distributions from a micro-sd card (8GB) with a SD adapter
bbonamin
  • 877
