I have Samsung ML-2850 and I'm wondering if the quality of greay areas could be better. This is an example print:
print example
As you can see, letters and black parts are pretty nice, but the part around the "6" should be filled grey. This is printed with 1200dpi and still I can't manage to get a better quality of grey parts. Is this normal for cheap homer b/w laser printers? Is there anything I can do? Are there special b/w printers which can print also greay levels nice?
Edit: It seems as if I overestimated the quality of grey parts printed by laser printers. Finally I printed the document with a professional laser printer. It is a bit better, but still you can see the dots.
lumbric
  • 838
    how much zoom you have applied in this image? And what program is used to generate the image, which operational system ? some more information would be good to help us... – woliveirajr Apr 25 '12 at 15:55
5 Answers5
As you perhaps know, all "Black and White"/"monochrome" laser printers are exactly that, they cannot really print intermediate colours or shades such as grey. They simulate gray by printing small dots and varying the spacing and arrangement of those dots. This is called dithering or halftoning. From a distance our eyes cannot distinguish the dots and see gray.
You can increase the quality of this illusion by tweaking the printer / driver settings but you cannot eliminate it completely.
The ML-2850 supports Postscript, it's a long shot but try a Postscript driver (you can add a separate printer entry in addition to the existing one) - The default driver is probably PCL6 or SPL.
No, to get a solid gray you'd need an offset printer to do spot color
Using a limited number of color inks, or specific color inks in addition to the primary colors, is referred to as "spot color" printing. Generally, spot-color inks are specific formulations that are designed to print alone, rather than to blend with other inks on the paper to produce various hues and shades. The range of available spot color inks, much like paint, is nearly unlimited, and much more varied than the colors that can be produced by four-color-process printing. Spot-color inks range from subtle pastels to intense fluorescents to reflective metallics.
RedGrittyBrick
  • 81,981
  • 135
  • 205
Try to set your printer quality. Some printers allow you to set the quality to "Draft", "Best", or something along those lines.
Also, check the "Halftoning" option in "Advanced options" (if you have something like that).
Ove
  • 1,597
  • Ah sorry, I forgot to mention that. I did check these settings. Do I get you right that your Canon is able to print grey levels more beautiful? – lumbric Apr 25 '12 at 15:20
  • I suggest editing your question. – Xavierjazz Apr 25 '12 at 15:26
    @lumbric Please post your document online somewhere, and I will download it, print it and take a picture for you. – Ove Apr 26 '12 at 07:13
Yes, for consumer use (not as offset which is not for normal consumer printing), but that would be inkjet, not laser printers. Monochrome inkjet printers like Epson M series (M105/200, etc.), Epson K series (K100/200) are some examples.
Monochrome laser printers usually have difficulties with printing solid block of color, being black or grey shades.
    Inkjet printers also use [dithering](http://www.xyanni.com/images/Presentation/Xyanni%20Macart.pdf) - the arrangement of dots may differ but they are still dots, not continuous pigment. So far as I can tell, the printers you mention are normal inkjets and will use dithering to simulate shades of grey. – RedGrittyBrick Nov 11 '15 at 17:13
  • @RedGrittyBrick, Wow, very interesting to know this. However, to my eyes, the shades of grey produced by inkjet and offset are much nicer than the ugly one printed by my laser printer (P1102). Don't know how high-end laser printer do any better, though. I once printed using a color laser printer in my university and things looks much better, almost comparable to inkjet output. Any idea? – Huy - Vuong Do Thanh Nov 12 '15 at 04:34
    @Huy-VuongDoThanh: Dots from inkjet printers will bleed, making softer borders. Or it may print gray by mixing colored inks instead of dithering black. Color lasers can do mixing as well, there's usually a setting controlling how grays are produced simply because mixing 3 colored toners costs quite a bit more than the black toner. – Ben Voigt Dec 10 '16 at 22:54
Same problem here when I print scans with my laser printer if I scan images to color or gray scale. There are lots of dots instead of solid lines or shapes, text/letters literally consist of a few dots.
What I found is first I need to convert scanned images to black and white or scan them in B&W mode and only then send them to the printer.
Conversion to B&W is possible in MS Paint, Channel Mixer (Photoshop) use a B&W converson insert or Lightroom. I just googled it to find out how it's done.
venik
We used to have in the Windows XP days a TSR that acted as a printer driver. What you did was tell this TSR which printer to print two and it would reconfigure the documents being sent into varying patterns instead of just black toner dots on white paper. Instead of general x patterns for grey scale/halftone you got ovals, triangles, e.t.c. It was useful for light grey on white paper like printing out a washer dryer product page from a web site which conventionally never worked out for monochrome. The built in pattern in the physical printers options is very limited. I've seen up to 24x24 pattern to simulate a grey level but that is still in the same dots pattern. So you needed something in between (the TSR) to provide a more useful pattern.
