I've got a copy of Spotmau's Bootsuite 2012, which is an utterly fantastic tool. It has completely replaced Bart PE for me, and I relied on BPE for YEARS.
Anyway, the issue I'm having is that the Bootsuite installer utility will only create bootable USB flash drives, or bootable CDs. The USB hard drive is detected as a hard drive instead of as a USB device, and as such I cannot use the included app to install to the USB HDD.
Is there a way of either copying the files from a bootable flash drive to a USB HDD and making that work, or of taking an .ISO of the bootable CD and using that to make the portable HD bootable?
The flash drives I've made of it are great as I can always have it with me [have 16GB dangling from my keychain. :) ], but my USB hard drive is FAR faster than any flash drive I have, so I'd like to be able to use that when I'm working out of my office or happen to have it with me.
user66001
  • 1,228
Sootah
  • 569
Take a look at http://unetbootin.sourceforge.net/
unetbootin looks like just what you're looking for. Keep in mind it may not enable persistence
steve
  • 612
  • Tried that, it only shows my hard drives that are connected via SATA, or USB flash drives. For some reason my USB portable hard drives it doesn't support. – Sootah Jun 26 '12 at 08:01
  • well if you know linux well enough you might be able to make it happen.you could try making a bootable flash drive and dd it to your usb hd :) – steve Jun 26 '12 at 15:29
Try an earlier version of unetbootin that supported showing all drive letters. Version 506 for example:
http://sourceforge.net/projects/unetbootin/files/UNetbootin/506/
Viller
unetbootin will surely do the trick for you if you are using any of the debian based operating systems to create a bootable HDD
steps:
1)sudo apt-get install unetbootin
2)fire up unetbootin (you will need root access)
3)select your image file
4)select removable devices
tick the option that says "show all devices"
5)select device and start writing to it.
but unetbootin doesn't support this feature in windows (at least with newer versions).
Ashildr
  • 2,698
  • 45
