I have a Dell Latitude E6410, which uses an Intel Ultimate N-6300 Wireless card. iwconfig does not show the Noise level of the wireless interface , wlan0. Does anyone know the reason for that?
precise@ubuntu:~/Desktop/Work/transmitter$ iwconfig
lo no wireless extensions.
mon0    IEEE 802.11abgn Mode:Monitor Tx-Power=15 dBm
        Retry long limit:7 RTS thr:off Fragment thr:off
        Power Management:off
wlan0   IEEE 802.11abgn  ESSID:"AirPennNet"
        Mode:Managed  Frequency:2.412 GHz  Access Point: D8:C7:C8:D7:A6:C1
        Bit Rate=130 Mb/s  Tx-Power=15 dBm
        Power Management:on
        Link Quality=65/70  Signal level=-45 dBm
        Rx invalid nwid:0  Rx  invalid crypt:0  Rx invalid frag:0
        Tx excessive retries:800  Invalid misc:540  Missed beacon:0
eth0    no wireless extensions.
I tried to use cat /proc/net/wireless and got these results:
Inter-| sta-|   Quality        |  Discarded packets         | Missed | WE
 face | tus | link level noise | nwid crypt frag retry misc | beacon | 22
 wlan0: 0000   64.  -46.  -256      0     0    0   818  566        0
Is -256 the noise level? How do I interpret this in dBm?
Marten Koetsier
  • 123
hektor
  • 163
The reason is that typically the LQI (Link Quality Indicator) and RSSI (Received Signal Strength Indication) are used as relative measurements of the quality and strength.
Look at this line:
Retry long limit:7 RTS thr:off Fragment thr:off Power Management:on Link Quality=65/70 Signal level=-45 dBm
In particular the end of it:
There is the link quality and signal level, which should give an indication of how well the connection is. The link I gave above details how to interpret them, you'll want to use these instead of the noise.
As for the noise value, you've got that right:
Inter-| sta- | Quality          | Discarded packets          | Missed | WE
Note the -46 which is your signal level (in dBm), the -256 is indeed the noise level (in dBm).
Tamara Wijsman
  • 57,083
  • 185
  • 256
There is another way: wavemon. It can be found in many distros. A nice curses based wireless information visualization program.
btw the -256 noise level seems to say that no value is returned by driver.
akostadinov
  • 1,375
