On a PC (HP ML110 G60), with no soundcard, Can I achieve sound/microphone plugging a USB sound card? Runnning Linux.
Asked
Active
Viewed 184 times
Yes but you must ensure that drivers are available for your chosen Operating System.
The link you gave says
Operating systems: Win XP/Vista/Win 2000/Win 98/Win ME/Mac OS or a Sony Playstation 3
So the vendors of that specific device do not provide Linux drivers.
I'd search the intertubes for one that does.
RedGrittyBrick
- 81,981
- 20
- 135
- 205
I've read about people about using that product for Linux. What about USB speakers, will they work out of the box? – jacktrades Jan 28 '13 at 15:29
1@jacktrades: I'd expect USB speakers to work out of the box. This is because these usually conform to a standard USB device class. I'd still check (ask the vendor - that way you can return for a refund if they are not fit for the specific purpose for which they were expressly purchased) – RedGrittyBrick Jan 28 '13 at 15:33
that standard USB profile will it work even for Linux? So those USB speakers have a built in audio card.... – jacktrades Jan 28 '13 at 15:35
@Jacktrades: USB speakers mostly don't contain audio circuitry to support all the features you'd expect of a sound card: microphone-input, host-based volume-mixing, etc. They are examples of powered-speakers (i.e. a bit like "monitors") rather than passive-speakers in that they contain an audio amplifier. – RedGrittyBrick Jan 28 '13 at 15:41
they should contain a simplified version of an audio card then, right? it's an audio card at the end of the day – jacktrades Jan 28 '13 at 15:45
@jacktrades: Nope. Cars and planes both have wheels, that doesn't mean a car is a plane at the end of the day. A USB speaker and a USB "sound-card" are both USB audio devices. I wouldn't take it further than that. – RedGrittyBrick Jan 28 '13 at 16:10
