I'm running an HP Pavilion dv6-3010us, with a Radeon HD 4200 series GPU. I have updated the ATI Catalyst Control Center, and now it's completely changed to AMD Vision Engine Control Center.
I have removed the laptop's monitor and hooked it up to a Dell 2009wt monitor that I bought recently via the VGA connection. I have also manually installed Dell's driver for it, and the Device Manager recognizes it as the 2009wt that it is. However, the Vision Engine Control Center only recognizes it as "Unknown Display," and a CRT at that.
Does anyone know why it's doing this, or some way I can force a manual detection, similar to forcing the monitor driver to update even though Windows thought "Generic Non-PnP Monitor" was best?
Alternatively, will I have more luck using an adapter to hook up the HDMI out of the laptop to the DVI in on the monitor?
EDIT: My HDMI to DVI adapter cable just arrived, and it works perfectly. The settings adjusted instantly when I plugged it in (the monitor was on auto-detect), and now I'm running max resolution with a 16:10 picture!
Should I answer my own question and mark that as best, or just leave the question alone now?
