I heard that charging a Li-Ion battery all the time is practically harmful for the battery and significantly reduces its useful capacity over time. Is this true? Should I disconnect the power cord from my laptop every time it isn't used for a long period of time, for example, at night?
If the answer is yes, does it apply to only bigger batteries or to smaller ones (for example, cellphone, tablet) too?
rishat
  • 1,327
    the problem for Li-Ion batteries life over time is **heat** rather than the recharge process itself. – danicotra Jul 21 '15 at 22:06
    So, if the heat matters, and modern charging sets are effective enough to bypass battery when it's been charged, thus causing no heat, one may consider keeping a device on power cord 24/7 risk-free (in context of electrons and heat and battery and stuff)? Any other factors involved? – rishat Jul 21 '15 at 22:26
  • In theory, yes. In reality, no. Modern computer build in with hardware current control, once it is fully charged, it will use ac power instead, you can touch the battery when it is charing and fully charged to feel the different. – Bilo Jul 22 '15 at 01:37
  • do consider anyway that an unmounted battery kept in a cool dry place is certainly less subject to warming issues than one mounted on laptop. – danicotra Jul 23 '15 at 18:22
  • P.S. : kept aside in a cool dry place **not fully charged** of course (see DrMoishe Pippik answer below). – danicotra Jul 23 '15 at 18:24
Li-ion batteries tend to deteriorate faster if left 100% charged (and of course may be ruined by complete discharging). "Overcharge up to 5.2 volts leads to the synthesis of cobalt(IV) oxide... The cobalt electrode reaction is only reversible for x < 0.5, limiting the depth of discharge allowable." Also, when left fully charged, the lithium ions, intercalated in the negative electrode, cause it that electrode to slowly expand and lose cohesion. For that reason, laptop manufacturers such as Toshiba, Samsung and Sony have added a power mode that limits battery charge to 50% or 80%, if the laptop is used primarily from the AC mains.
For that reason, you might intentionally discharge the battery halfway and remove it, to extend its life, but the disadvantage is that it no longer functions as a UPS. A better option would be to find a utility similar to the Samsung Battery Life Extender that would keep the battery at ~50-80% charge.
DrMoishe Pippik
  • 25,661
  • 54
