After a new installation of Ubuntu 18.04.3, there was no sound output. A couple of devices were identified, and a dummy showed up, selecting none of those worked. Speaker test nil.
At first I thought it was a codec problem, so I installed VLC but still no luck.
I tried some stuff with alsa (read in a forum), which seems to have made it worse as now no devices are showing at all. All sound settings greyed out, and sometimes pop up again - unstable. Test gives no result either in settings or terminal.
output devices shown
speaker-test output in terminal
Log shows:
[pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="0" name="platform-bytcr_rt5651" card_name="alsa_card.platform-bytcr_rt5651" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
[pulseaudio] module-alsa-card.c: Failed to find a working profile.
Audio Port: ASoC: no backend DAIs enabled for Audio Port
Can someone please help?
Would rebuilding ALSA be a good first step? As is here: Sound Settings is missing all output devices > This did not work for me.
I'm a complete newbie so don't want to give any more false steps here.
Thanks!
JBC
  • Hi, have you tried to install the driver needed? You can go to Software & Updates, then go to Additional Drivers, and look if there's a driver for that. May i know how you set up your system? Is it onboard audio / DAC Dongle or anything else? – Chris Qiang Jan 05 '20 at 10:33
  • Hi Chris! Thanks for the reply. No additional drivers in updates. No idea of the setup. How do I find out? If this furthers, it's a cheap laptop. – JBC Jan 05 '20 at 10:37
  • @Chris Could this be it? 00:03.0 Multimedia controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit (rev 36) Subsystem: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Imaging Unit Flags: fast devsel, IRQ 255 [virtual] Memory at 91000000 (32-bit, non-prefetchable) [size=4M] Capabilities: [80] Power Management version 2 Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit- Kernel driver in use: intel_atomisp2_pm Kernel modules: intel_atomisp2_pm – JBC Jan 05 '20 at 11:06
This worked:
https://github.com/plbossart/UCM/issues/13#issuecomment-399256736
Basically installing the driver, selecting the right output in alsamixer and waiting a moment.
JBC
Update:
Tried Ubuntu 20.04 Live USB and this issue is fixed. This processor sound capability is now supported out of the box.
JBC
