I downloaded a disk image of Ubuntu 14.04 and when tried to run it inside of a virtual machine within Virtual Box it only pops up with a blank screen, and nothing else. Could installing install guest additions fix this problem?
Asked
Active
Viewed 3,319 times
1possible duplicate of [My computer boots to a black screen, what options do I have to fix it?](http://askubuntu.com/questions/162075/my-computer-boots-to-a-black-screen-what-options-do-i-have-to-fix-it) – Richard Apr 27 '14 at 19:28
When you say you downloaded a "disk image" do you mean an ISO file or a VirtualBox image (VDI)? – user898763452 Jul 18 '14 at 16:48
How much memory have you given to use for the Ubuntu VM?
You need at least 4GB for Unity and around 2GB for Lubuntu.
I think you didn't give enough memory to install it, and that is why it is getting stuck there.
belacqua
- 22,880
- 23
- 88
- 108
Yhal Htet Aung
- 136
- 9
I ran into the same issue. You can try my solution : after increasing both the guest and video memory, my VM booted to the desktop.
Welcome to Ask Ubuntu! Please don't add "thanks" as answers. Invest some time in the site and you will gain sufficient [privileges](http://askubuntu.com/privileges) to upvote answers you like, which is the Ask Ubuntu way of saying thank you. – Warren Hill Jul 18 '14 at 17:06
@WarrenHill This isn't a 'thanks' answer -- the second sentence is giving a solution (may be not detailed enough to be very helpful, but still not 'thanks'.) – belacqua Jul 18 '14 at 19:34
For me I had to enable hardware virtualization (bios setting) first to increase the vm memory. Instructions for lenovo ideapad (intel processor running windows)
Yuri Feldman
- 111
- 3
While this link may answer the question, it is better to include the essential parts of the answer here and provide the link for reference. Link-only answers can become invalid if the linked page changes. – αғsнιη Oct 19 '14 at 05:56
I'd rather add the link in the comments to a good answer, but I have insufficient reputation :) – Yuri Feldman Oct 20 '14 at 09:01
