Let's say I have a spreadsheet look like this.
A |B
1 |1.0 2016-05-07
2 |0.5 2016-04-12
3 |x.y yyyy-MM-dd
How can I sum those first values(1.0, 0.5)?
Jin Kwon
  • 336
EDIT - MY MISTAKE - YOU CAN DO IT WITH a basic Excel functions - see answer!
Here's another way using a VBA module, and custom public function
Insert this in VBA Code
Public Function SumLeftData(rgeData As Range) As Double
    Dim celVal  As Object
    For Each celVal In rgeData.Cells
        SumLeftData = SumLeftData + Left(celVal, 3)
    Next
End Function
For your example, you would then insert formula in cell C3 (or wherever) that =SumLeftData(B1:B3)
NOTE
Make sure it's in Module1 - not in Workbook code
How do I add VBA in MS Office?
dbmitch
  • 134
You can use array formula like the following:
=SUMPRODUCT(1*LEFT(A1:A3,FIND(" ",A1,1)-1))
where A1:A3 is the column of your data, and you have always a space between numbers and date, the formula finds the first space and read the number on the left and use Ctrl + Shift + Enter instead of 'Enter' for array formula, sumproduct will add the numbers.
In case your Data does not start always with numbers you can use:
=SUMPRODUCT(IF(ISNUMBER(VALUE(LEFT(A1:A3,FIND(" ",A1,1)-1))),1*LEFT(A1:A3,FIND(" ",A1,1)-1),0))
Sam
  • 884
