Possible Duplicate:
How do I display all power plans in Windows 7 notification area?
While using the Laptop, I frequently change my power options, based on the applications that I am using, but while changing these options, its a pain as only 2 power options are listed in the tool at System Tray.
Any Idea, how to list all power options, on the system tray?
Starx
  • 2,271
  • 37
  • exact duplicate of [How do I display all power plans in Windows 7 notification area?](http://superuser.com/questions/160866/how-do-i-display-all-power-plans-in-windows-7-notification-area) – Mehper C. Palavuzlar Jul 11 '10 at 12:11
Try Battery Care, a freeware tool that does more than allowing you to easily change the power plans (Power Saver, Balanced and High Performance) . See this Battery Care review
Nicu Zecheru
  • 5,492
  • 46
